leaking fuel under hood
I have a 97 f150 and have had a rat/squirrel get under hood and chewed fuel line. Is this easy to replace? can you patch the line?
RE: leaking fuel under hood
if it is a steel then you should be able to cut the bad part out and usingnew steel line andcouplers to rejoin it together.
Rat chewed your fuel line? I thought all the fuel lines were metal. Are you sure you don't have a fuel pressure regulator leaking? What engine do you have and where bouts is the leak coming from?
