lock solenoid
Old Feb 14, 2012 | 09:21 PM
nelpasa's Avatar
Default lock solenoid
1990 f-150. how to test door lock solenoid?
Old Feb 16, 2012 | 11:13 AM
imp's Avatar
imp
Use ohmmeter to measure coil resistance.
If coil resistance measures very low, say, less than 10 ohms, it is short-circuited. If coil resistance measures very high, thousands of ohms, it is open-circuited. Either condition calls for replacement. Sorry, I do not have my manual available listing expected normal coil resistance. imp
Old Feb 16, 2012 | 06:05 PM
way2old's Avatar
Remove the door panel and check for voltage going to the solenoid. If there is current when you toggle the switch, the solenoid is bad. One side will current going to it when the switch is activated.
jdm
Feb 26, 2006 08:38 PM
1Harley1
Jan 24, 2006 05:20 PM
shelleyrick
Dec 10, 2005 06:29 PM
Mobile AV
Aug 17, 2005 04:01 PM
redtide265
Jun 29, 2005 04:48 PM
