Not Starting
If there is no power going from the solenoid to the starter, does he not think the issue could be there or the ignition? cause it was blowing ignition fuses until I took off the dash Now not blowing fuses. Problem is, when I connect the 2 ends of the solenoid, I hear it open and close. But then I try to start it, it will not open and close. When I turn the ignition, I get power to the cab and on the dash, but dont even hear any clicking in the engine
RE: Not Starting
turn your key to the run position, jump across the positive side of the selonoid switch,if it starts the problem is in the selonoid email me back james
RE: Not Starting
Agreed.
