problem engine swap 87 efi >> 76 f100
hi,
I have a 76 f100 in mint shape, the original 360 blew, so i bought a running 87 f150 with a 302 efi.
I got the motor and tranny in place, mounted the computer, saved the original wiring harness and used it. but i can't seem to get any spark.
Does any one have a wiring diagram that just uses the ecu and all the necessary sensors, relais etc. so i can eliminate all the other sh&t.
there must be something like that arround. ecu <<--->> sensors, injectors and etc
thanks in advance
Matt
thanks in advance
Matt
You in for a pain now buddy.
I know people who have attemped this swap (or one simlaer) and after 3 years still have wireing problems.
Since the EFI 302's used basically the same system as a Carburated 302, check all the usuals. My guess is the TFI Module.
later,
Dustin
later,
Dustin
