Rear axle shaft help..
Old May 10, 2008 | 12:38 PM
f150sc's Avatar
Default Rear axle shaft help..
If some one could please tell me the diference between tag numbers. Susch as 828 or the 829? I have an 02 f150 supercrew and the axle is grooved pretty bad. Some of the parts store here don't know anything about the parts they sale. Also I asked for an axle save and they didn't know what the hell it was..if some can correct me it's also kown as a repair bearing or are thy two different items?
Old May 10, 2008 | 01:30 PM
david paul's Avatar
Default RE: Rear axle shaft help..
go to a bearing supply with your old bearing and seal they should be able to fix you up that is where i go in KNOXVILLE,TN.
Old May 11, 2008 | 11:14 PM
f150sc's Avatar
ok..so i think im goino to replace the axle..and have found out that the 829 vs the 828..the 829 is locking..but the spline count is the same..and i think the lgnth is to..so can the 829 axle shaft be used in place of the 828?...im replacing the passengers side (right) side..any suggestions?
jmedeiros40
Mar 22, 2013 08:55 AM
crispyc21
Mar 13, 2013 09:08 PM
CaptJack101
Mar 12, 2008 12:30 AM
jobi
Oct 21, 2007 10:51 AM
howboutrita
Sep 5, 2006 03:31 AM
