Rust Fix
Hey yall my92 flareside has rusted out holes on the extened cab part of the body i need to know how to fix the rust so i can respray thanx to yall who can help.
[IMG]local://upfiles/10121/ED27EB83CCEE42358B5FF6A38809A977.jpg[/IMG] |
RE: Rust Fix
Usually I grind and sand the bad metal and a little around the edges. Then I usually take primer and seal the metal (unless I'm welding in a panel) then I allow it to dry. Next I get a fiberglass body putty like Mar-Glass and lay it on (especially from the back side if possible) and let it dry. ThenI take a very rough file and knock out any lumps on the surface and sand it smooth (first with 40 grit then 80 grit then fine papers if I care that much). LastI lay another coat of primer on (inside and out). Then paint to match.
RE: Rust Fix
You can just get repair panels at your local parts store and do it right if you plan to keep it for a few years. It does require some welding and seam blending. Even if you try to sell it it will look better if there isn't a lot of filler to be found. If you just cover it with any kind of filler you will be doing the same thing in 2 years.
| All times are GMT -5. The time now is 05:49 AM. |
