Somethings Weird
Old Feb 10, 2009 | 06:32 PM
Leandro's Avatar
Angry Somethings Weird
So I have just recently purchased a 2000 F-150 with 150xxx miles on it and the guy said he changed the spark plugs and wires, which it looks like he did recently and he also said he replaced the EGR valve. I have a an error code telling me EGR Flow Insufficent. I`ve been doing some research and people say to take off the egr valve and the throttle body cover and clean something?
Also someone said to clean out the EGR tubes??
The engine is giving out sometimes..not bad enough to judge it as a misfire but ill just be driving at a steady speed and it will once and a while kinda choke real quick. Also when im in like 3rd gear and step on it it starts choking alot? what could this be??
Old Feb 11, 2009 | 01:45 PM
oldtimer35's Avatar
You didn't mention what engine was in this truck. If it is the 4.6 V8, then yes, you may have a problem with the EGR ports plugging up. Then you remove the throttle body assembly and clean the ports our. If it is the 4.2 V6, then you must remove the upper intake, because it is ported at each intake port, and this will give a slight miss under load.
However, you say it has a code in it for insufficient flow. May not be the EGR or ports, but the sensor that is the problem. Have replace many for this code, both in V6 and V8 motors.
Old Feb 12, 2009 | 05:45 PM
Leandro's Avatar
This is the 4.2 v6 engine..the previous owner said that he already replaced EGR but idk what sensor are you speaking of?
54Strife
Jul 13, 2006 12:55 PM
rusty ol ranger
Jun 12, 2006 04:01 PM
Taurusdude2003
Feb 22, 2006 10:04 PM
mstngmach
Oct 11, 2005 09:14 PM
ehkneebreeashun
Jan 12, 2005 03:22 PM
