Starting/Clicking Sound
hello everyone. I have a problem with my 1999 Ford f150 V6 4.2 Liter. About a couple of months ago I went to walmart & my truck was running fine, they when I tried to start it later nothing. So I had the solenoid replaced. A month later I tried to start the truck and got a click sound.
Everytime I turn the key just one click sound, so I had the starter replaced. Then another month goes by present day, I once again at walmart tried to start the truck, and once again when I tried to start the truck a single click with every turn of the key. I replaced the solenoid, replaced the starter, replace the terminals on a Red Top Optima, the battery reads fine, what could it be? |
Had a similar problem before on my old car. Ended up being a bad ground. Idk if that is your problem but its worth a shot to look into.
Have you considered staying away from Walmart?
Seriously though,a thorough check of all the ground connections as stated in an earlier post is a good place to start. Checking the connections is more than looking at them, you need to loosen and retighten them. It would be a good idea to make sure the ignition switch is sending full voltage down to the solenoid. |
(Post 65347)
+1 on the above. Chack grounds and make sure you are getting voltage. |
Thanks for all your reply's I'll check into the ground wires. Also lol on walmart.:D
Did your issue got solved or not?
Just looking over the posts and a question comes to mind.
In the original post ,the statement reads ,"replaced the terminals". Could it be that the vehicle has a defective/corroded battery cable? Wonder just what terminals were replaced and why. Just curious. |
Originally Posted by joshtimber
(Post 65487)
(Post 65489)
Could it be that the vehicle has a defective/corroded battery cable?Wonder just what terminals were replaced and why. Just curious.
So everything is fixed and I couldn't be any happier, just in time before Winter hits........ |
Does this mean that now you can go to Walmart again?
(Post 65580)
So the moral of the story is "If your Ford breaks down at Walmart there's a Ford dealer nearby"........ |
