Too lean???
Old Dec 13, 2009 | 10:12 AM
ahooten's Avatar
Unhappy Too lean???
I recently replaced the spark plugs in my 98 f150 4.6. Everything ran fine for about two weeks and now I'm getting a code that says my bank 2 is running lean and once in awhile a random misfire on C8. I'm thinking that its the injector on C8 but I was wondering if you guys had any tips or other suggestions. How would I tell if the injector is shot?
Thanks
Old Dec 14, 2009 | 11:29 AM
Bullitt94's Avatar
First thing I'd do is run some Sea Foam in the tank to try to clean the injector.
Old Dec 27, 2009 | 12:24 AM
Unioxia09's Avatar
Default Too lean
Pull the plugs if they are "White" or Grey its too lean. Check the timing if you havent already done so. The carb may need the idle circuit fattened up too.
skriz
Jun 6, 2007 10:07 AM
c2321
Apr 5, 2006 12:55 PM
jrminiquad
Jan 15, 2006 03:56 PM
palmateer
Apr 22, 2005 05:00 PM
