-   Ford F-150 (https://www.fordforum.com/forum/ford-f-150-14/)
-   -   Truck goes into fail safe mode on low oil pressure (https://www.fordforum.com/forum/ford-f-150-14/truck-goes-into-fail-safe-mode-low-oil-pressure-19009/)
fishfun83 Jan 4, 2010 11:54 AM
Need some help. My 2005 F150 once in a while goes into the fail safe mode while driving. It indicates low oil pressure but the engine is not low on oil and the pressure gauge does not drop. If I turn the key off, and restart, it seems to be fine. This has happened 5 or 6 times to me but thank goodness it has only happened at low speeds. I am concerned this may happen at high speeds someday and the steering wheel lock up. Any help or suggestions would be greatly appreciated.
eagle-eye Jan 4, 2010 09:55 PM
There is an oil pressure switch that goes bad on these trucks, it will cause all of your symptoms.
It is roughly 10 dollars at your local autozone!!
