wiring problem
Both wires on my injectors have power to them. Has anyone seen this before?
RE: wiring problem
Is this with the injector unplugged? If not, that would be normal as the pcm is the ground for the injector. If it is unplugged, then you have a short to power on that injector. Could be from the pcm or other power wire.
