05 F250 Dash panel removal
Old Jun 23, 2008 | 03:32 PM
dee004's Avatar
Default 05 F250 Dash panel removal
Does anyone know how to, or have a schematic of how to remove the dash panel on a 2005 F250 Super Duty. I need to get to the back of the radio to the auxiliary input. I don't want to crack or snap the panel pulling on the wrong spot or forget to remove a hidden screw or two.
Thanks Dee
Old Jun 23, 2008 | 04:20 PM
Default RE: 05 F250 Dash panel removal
The trim panel just snaps to the dash.. No screws..
I usually start from the left side and grab the trim panel with my finger nails and pull straight outward to snap it loose, then work my way around.. They unsnap very easy.. Pull gently and evenly on the lower area's 'close inward' to the column covers.. The panel is pretty tough, but use care in that area.. There'll be connector locks (red) on some of the connectors. They need to be revoved before the connector can be released.. If you just release the connectors more inboard to the radio area, you can usually position the trim panel upwards for the radio removal if you don't want to remove all the connectors..
Old Jun 23, 2008 | 07:36 PM
dee004's Avatar
Thanks Hayapower, that will be very usefull info.
Dee
ncolt
Canada, Over Seas & Elsewhere
Oct 7, 2012 04:13 PM
mrdgzpm
Apr 9, 2011 11:05 PM
f250nut
Feb 20, 2011 03:30 PM
SIC J
Feb 17, 2009 03:30 PM
ejfont2
Nov 26, 2007 08:43 AM
