1974 F250 Super Duty.
[IMG][/IMG] Does anybody know what rearend is in these trucks. I know they were made for pulling but coming aroud a corner it sounds like I'm doing 80 but really creaping about 40. A real mind teaser. I pull a 2200lb bass boat. I want to be able to get out of the hole on the steep ramps but I don't want to creep on the long highway hauls to the lake. The rearend I have doesn't work this way. What numbers should I have to get what I want? Thank you very much, Jeayman7533 |
RE: 1974 F250 Super Duty.
I'm going to put a 2105 intake on my 390. is the tork the same on the bolts as case iron intake?
You will have to read the manafactors spec's when you get it.[hr]I would say no they wont be the same tourqe.
You should have a tag on the rear to tell you what rear you have.
Moved to proper section
rusted away. I checked for it today.
Axle code on the door data plate?
