1989 F250 injector problem
Old Nov 9, 2007 | 10:37 PM
normsams's Avatar
Default 1989 F250 injector problem
Working on a F250 trying to locate a problem in the wiring from the distributor to the injectors. Have replaced the ECM, the distributor (the TF module), the throttle positioning sensor. When cranking engine, there is no injector signal. Can spray gas into intake, start engine, snap throttle and produce injector signal that way. Need more detailed wiring schematic and/or more info on electrical path for the signal in crank mode.[/align]
4Talons
May 4, 2009 10:38 AM
justsomeguy
Apr 9, 2008 07:52 AM
a_cmc_2b
Feb 6, 2008 09:47 PM
f250man
Apr 2, 2007 08:49 PM
JOE 1
Mar 2, 2007 04:19 PM
