1990 Fuel Line Problems
Is ther a check valve where the dual tank lines come together? If so is it above the front tank? Rear tank appears to be pumping fuel into the front tank and either has a cracked line or fuel is comming from front tank overflow out on the ground. Suspect a check valve is bad?????
