1995 ford f350
Old Feb 13, 2009 | 05:44 AM
skikatana's Avatar
Cool 1995 ford f350
how do you adjust the automatic shifter. It reads almost on the Neutral on the dash but is really in 2nd gear.
Old Feb 18, 2009 | 11:55 AM
If the selector is sloppy or hard to select the specific ranges, look under the column about half way down at the base of the 'main' column.. You'll see where the trans shift cable and selector lever attach to the shift tube.. There a 2 torx screws there that come loose and back out.. Make sure their tight.. If the shift selector feels tight without any excessive play, there's a 'thumb wheel' on the small white range indicator cable just below and behind the lower column dress cover.. Rotate the thumb wheel to correct the indication error..
Old Feb 25, 2009 | 11:19 AM
carmania11's Avatar
I cannot understand it. Can someone make it in detail.
cbutkaiv
Jul 26, 2015 04:18 PM
jogare
May 18, 2012 07:52 AM
HorchataKing
Mar 9, 2009 02:00 PM
Lariat 07
Sep 8, 2008 01:40 PM
skikatana
Jun 29, 2008 07:40 PM
