1995 OBS F350 cab and chassis spring code 4X4H
Having trouble finding the spring capacity for my 95 f350 cab and chassis. Door sticker code says 4X4H. It's a work truck and there isn't many factory options so maybe I just need to order HD leafs for this model.
It's a 460 5 speed 2wd dually and I don't plan to plow with it just haul a gooseneck so I'm guessing I wouldn't need the front max duty or anything but I do want it to be able to handle whatever I need to load or haul |
Welcome to the site 4X4H is,, 4 is the Aux/Opt usage code front.. X is the front spring code 4 is the Aux/Opt usage code rear H is the rear spring code Ford OE,, X code for the front is part number F4TA-5310-XA Code H for rear, is part number F4TA-5310-HA When sourcing replacements, X, H with M/Y you can find all the spring capacity and dimension specs... |
