1997 F-250 Door Locks Going Crazy and Horn and Dome Light
Old Aug 17, 2009 | 10:09 AM
ponway's Avatar
Default 1997 F-250 Door Locks Going Crazy and Horn and Dome Light
While going down the road, the door locks have started to go up and down repeatedly, the dome light will come on and the horn will blow at most inopportune times. Could this be a computer problem? This is a 1997 Ford F-250 Super Duty with the older style cab. Thanks for any help!
Old Aug 23, 2009 | 02:09 PM
itismej's Avatar
Default Dome Light
I had a similar problem but it was with the dome light and the exterior cab light. If I slowed down to below 15 mph, they would come on. As well it would not allow the alarm to set when this happened. I read a tech tip that instructed me to generously lube the door latch with silicon. I used remington gun oil. Problem solved.
Old Sep 18, 2009 | 07:37 PM
ponway's Avatar
Default Problem solved
Well, my Dad got it fixed, turned out that the truck keys needed to be reprogramed. That cost $35 at Ford and now everything works properly.
unclebigg
Nov 15, 2012 12:12 PM
NathanHale
Mar 30, 2009 06:18 PM
Zapman
Feb 16, 2009 06:29 PM
ngusto
Apr 7, 2008 09:57 PM
Mike11C
May 27, 2007 02:14 PM
