1998 ford f250 2wd
Hello,
I have a ford f250 2wd 7lug 5.4 v8. My front spindle is hot can only keep hands on for a few seconds before it starts to burn. I have replaced the wheel bearings and I didn't over tighten them rotor spins freely. Replaced both front calipers and brake pads. Still hot. Is this normal for a 2wd? I know on a 4x4 that means the bearings are bad. Anybody have any ideas thanks for the help |
A few questions,
How does the wheel that seems hot compare to the other front wheel? When you replaced the calipers did you clean and lube the caliper pins? Are you checking the wheels after some heavy braking? If there is air trapped in the caliper, when it gets warm will expand and cause some brake drag. |
(Post 96651)
A few questions,
(Post 96651)
A few questions,
The calipers bolt to 2 pins that allow the entire caliper to slide. Those are the pins I am referring to. They must be removed, pin surface cleaned and holes the pins go into must be cleaned out also,then lubricated with a synthetic grease that will not harm the rubber boots when installed. It does sound like one or both of the pins on the side that is getting hot are jammed full of rust, dirt ,etc. and may be difficult to slide. The caliper should have a little clearance at both top and bottom so it has room to move. Filing the rust off the spindle where the caliper slides also helps a lot.
