-   Ford F-250 & Ford F-350 (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/)
-   -   1999 F-350 4x4 (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/1999-f-350-4x4-26733/)
drillerb57 Mar 19, 2012 07:58 PM
1999 F-350 4x4
Hello all...I just bought a 99 F-350 (75,000 miles) 4x4 Standard shift. I was hoping for some help with spark plugs..I heard of horror stories of plugs that have stayed too long in the heads. Should I be worried.? Should I just change them to be on the safe side?
(yes I posted the same thread in the new lounge but nobody replied,,:confused:)
hanky Mar 20, 2012 03:42 AM
If you can check with a Ford dealer Parts dept. Give them your VIN # and they can tell you from that if you have one of the engines that could have that problem. All engines are not the same even the 5.4's.
Hayapower Mar 20, 2012 11:29 AM
The 99 Triton V10 under 'normal' driving conditions plug change interval is 100K.
They do have issues with the narrow band of plug threads, but not all take the threads with the plugs if carefully removed and tightened. There's a thread replacement tool to repair the damaged holes if the problem should occur with yours if/when changed..
spastik monkey Mar 20, 2012 10:44 PM
Just be careful and make sure you use the correct size wrench and take your time. You can also shoot some PB blaster on there to help loosen up the threads.
drillerb57 Mar 21, 2012 04:40 PM
Thanks for all the info...:)
