2000 F250 SD wiring for Lance camper
Old Aug 23, 2007 | 12:33 PM
tytolene's Avatar
Default 2000 F250 SD wiring for Lance camper
Has anyone wired their F250 for a Lance truck camper? I just purchased a 2000 Lancelite 845, and need to plug it into the truck. I got the Lance EP200 socket with 8' of wire harness from a camper store. It has the socket that plugs into the Lance at one end, and bare wires that needs spliced into the F250 at the other. Is there a recommended place to splice into the Ford harness? I followed the wires from the 7-pin connector at the hitch...up the drivers side frame rail...and to a connector abover the drivers front wheel well. Is there a break out harness that Ford sell to pick up the turn, running, and backup lights at this connector? Or should I splice into the 4 wires I need, midway back the frame rail?
Also, is this the correct function for these 4wire colors on the Ford?
yellow.............left turn
green...............right turn
brown/white.....running lights
black/green......backup lights
The only other wires are:
white.......8ga ground.......to the frame
black.......8ga hot, +12v.......from batt.pos.......to 30A circuit breaker.......to Relay.......to Lance harness
Any advice is appreciated on other peoples camper setups.
Thanks,
Ty
Old Aug 23, 2007 | 01:29 PM
Default RE: 2000 F250 SD wiring for Lance camper
Welcome to the site..
The wire color/functions are correct as you listed.. Trailer battery charge wire is Orange..
No splice harness or plug and play that I'm aware of, and usually a tie in along the harness run down the L/rail is done dictated by the camper/harness connection..
Old Mar 26, 2011 | 12:45 PM
JMK's Avatar
JMK
Is this the same wiring for a 1994 Ford F250? I will be installing the same Lance product.
ReelinRyan
Jan 20, 2013 09:22 AM
77FordF250
Nov 16, 2011 06:47 AM
L.L. Hoffman
Jul 31, 2011 09:09 PM
D.T.
Apr 7, 2009 06:43 PM
domesticfan
Jun 22, 2007 07:43 PM
