2000 ford f 250 air conditioner
Old Aug 24, 2007 | 05:41 PM
kylesandi338's Avatar
Default 2000 ford f 250 air conditioner
I have a 2000 ford f250 diseil. The air conditioner blows cold but it all of a sudden stopped blowing out of the vents on the dash. It still blows cold but it only blows out of the defrost vents by the windshield. I have no idea. I put it in 4 wheel drive and it all of a sudden stopped blowing out of the dash vents. any suggestions? I am broke and cant afford for the dealership to take me to the bank. Any help is good. thanks alot kyle
Old Aug 24, 2007 | 09:20 PM
Default RE: 2000 ford f 250 air conditioner
The default position for the vents isthe defrost mode/position.. Should be default to defrost in heat mode as well.. The diesels have a vacuum pump mounted to the R/Passenger side inner wheel well area to supply vacuum for the climate control as well as ESOF auto lock if equipped.. If the pump fails, or a vacuum leak develops, the vents will default to defrost.. Pump failures are fairly common, but it should be 'run tested' and checked for a possible system leak.. If a vacuum leak is present, generally the pump will continually run.. Also check for power distribution to the pump, but if the fuse blows there's other components affected that would show up...
Here's a pic of the vacuum pump...
[IMG]local://upfiles/6756/8DBD29D40DB1447CA57A3E004CB2C0CE.gif[/IMG]
Old Aug 24, 2007 | 09:24 PM
Is your truck a Manual hub/T case, or ESOF Auto Locking hubs?
Old Aug 28, 2007 | 05:17 PM
thanks for the reply. It has manual hubs. It all of a sudden started blowing on all vents. I have no idea what is going on. sounds like something might be going bad. any help appreciated. kyle
Old Aug 28, 2007 | 07:43 PM
Did you check the electric vacuum pump?
Old Sep 7, 2007 | 12:12 PM
craigatkins's Avatar
Just experienced the exact same problem. I have a 2000 F350 that has been sitting for about 6 months and this summer had that problem. It would go between air and no air blowing out of the vents about every 30 minutes. After making an appointment to have it checked it just started working properly on its own. Hope it stays that way
JDMAN1
Oct 9, 2023 06:50 AM
kctires
Aug 10, 2016 03:52 PM
kymailman98
Sep 2, 2008 01:00 PM
thfrederick
May 13, 2006 04:43 PM
JDMAN1
Jun 8, 2005 11:51 PM
