2001 F-250 V-10 Noise under load
Old Dec 31, 2005 | 01:52 PM
jjcaldwell's Avatar
Default 2001 F-250 V-10 Noise under load
I have started hearing what sounds like an exhaust leak, but no leak has been found. When pulling away from a dead stop, accelerating up a hill, or when a heavy load is on the truck, is when this noise is heard the most. I have done the following to try an isolate the issue. Replaced all spark plugs, replaced one coil and moved it to all 10 plugs, no difference. Had the codes checked several times, but each time it says I need to drive another 100+ miles. Any thoughts on what may be the cause of the noise, and the reason the codes can not be read?
jlee
Aug 18, 2007 07:03 AM
JoeFed
May 17, 2007 07:20 PM
Sailormilan2
May 8, 2007 04:34 AM
ford2003
Aug 15, 2006 11:38 PM
ken441959
Canada, Over Seas & Elsewhere
Jan 23, 2006 07:01 PM
