2002 F250 V10 smooth idle to intermittant rough idle
Old Mar 20, 2008 | 03:19 PM
Olpapa's Avatar
Default 2002 F250 V10 smooth idle to intermittant rough idle
Not sure what is going on. I have a 2002 F250 V10 that runs and idles fine. However, it is starting to act like it has a bad miss and the whole pickup shakes when this starts running rough. When I'm driving down smooth asphault sometimes it acts as if I'm crossing railroad tracks. This happens from 3 to 10 seconds...Why?
It has about 96,000 miles on it but it has never ran bad or left me walking. What is going on? Sometimes if feels as though the transmission is slipping when this is going one....
Thanks[:@]
Old Mar 21, 2008 | 12:15 PM
ziggy's Avatar
Default RE: 2002 F250 V10 smooth idle to intermittant rough idle
Hi. Did you have your ignition coils checked? I had coils go bad on my 5.4, and my v10. My trucks acted the same way. They seemed to idle o.k, but when you get into the throttle the engine would miss like crazy, and the whole truck would shake. On the v10 the bad coil would fire sometimes and then quit. It seemed to run good, and then that coil would stop firing again, and the truck would start to miss. Hope this helps.
Old Apr 1, 2008 | 09:07 AM
Olpapa's Avatar
Thank you ziggy, that is exactly what it was...#10 cylinder's ignition coil.
Thanks again,
Olpapa
Old May 18, 2008 | 03:22 PM
motorsports12's Avatar
how did you have them checked - is it something i can do myself or does it have to be a dealer - it sounds exactly like what my truck is doing right now and it is really annoying plus i want to make it right
Deano2
May 5, 2012 02:40 PM
ikala476
Apr 18, 2010 01:05 PM
bosanci28
Apr 17, 2010 11:33 PM
gba3009
Feb 6, 2009 01:52 PM
babyblue00SE
Aug 23, 2007 01:17 PM
