F 250-350 wireing diagram and AC ?
im sure someone knows were to find the wiring diagram or maybe you can tell me why my AC fan **** only turns the fan on when i put it to high, none of the other settings work (low - med etc..) i was told it was a relay and it probably is but...and maybe you could tell me how to know if im on internal air or outside air?
Thanks
Thanks
RE: F 250-350 wireing diagram and AC ?
Standard climate control, or EATC (electronic temp control)
Most likely the blower resistor mounted into the heater/AC plenum next to the fan blower.. The internal 'thermal limiter' burns out and the only setting that remains is the high position/function...
Lisa
08-07-2008 08:46 PM
