2006 powerstroke wont start
I have a 2006 f250 powerstroke that dosent want to start. the engine turns over and fires but dies out. the problem is gtting progesevely worse. the truck will start after a while and will start the rest of the day but come morning, good luck. i dont think it is the glow plugs because iv plugged in the block heater and same results... im late for work. any help would be greatly apprecited.
RE: 2006 powerstroke wont start
It still could be the glow plug's or the glow plug relay, the block heater just keeps the coolant temp around 100 degree's i do believe and does help it start easier but the glow plug's heat the in coming air too a certain temp too help start
[align=left] [/align] |
Sounds like its the Glow Plug Relay under the hood, its in the box on the drivers side closest to the cab, its big and gray, should be about $15 at the dealer. Thats where I would start. Does the Glow plug light go out when you leave the key on for a minute first thing in the am?
