earlier diesel fuel tanks, 1984 to 1990
Old 02-16-2012, 01:39 PM
indigoshaman's Avatar
Default earlier diesel fuel tanks, 1984 to 1990
i have a F250 XLT Lariat model, with stock rear fuel which is causing me problems... i have heard that ford makes a stock replacement tank for diesel whose capacity is 38 gallons.......
anyone know if there are other sources for purchasing this item? I have had no luck so far locating this tank. some one referred me to the '64 Bronco tank but it is galvanized so wont work for diesel.........is there an after market supplier who may be able to help?
Come on you Ford guys, get er done and let me know if you have any info on this...
indigoshaman
Old 02-19-2012, 11:07 PM
Faceman's Avatar
I just went to a parts store and ordered one.
Old 02-20-2012, 02:04 PM
Ford Fanatic's Avatar
You need to know the year, wheelbase, and 2 or 4 wheel drive to get started.
Old 02-20-2012, 11:57 PM
Default need to know year....
ok i will play...
mine is a 1985 f250, xlt lariat super cab, 6.9L diesel motor....
4x4 full size bed truck with stock rear and also a side tank stock...
Old 02-21-2012, 09:15 AM
Front 16 gallon tank $139.49, Rear 19 gallon tank $133.99 @ N.A.P.A. .........................tag , you're it!
Old 02-22-2012, 04:22 PM
lol... hey i have found a 32 gal tank which will bolt right up to stock... will get info and post soon as i research it....
also considering van fuel tank that is diesel for e350 and there is one for the bronco full size Bronco u150 which is 31 gals
also considering putting a chevy or gmc as it were 1988 diesel fuel tank with chevy sending uniti and pickup and fit it up in there, it is 38 gals also 1984 has one
3/4 ton 4x4 diesel tank available.... if ford cant get me what i want i will look elsewhere and fit it up...
tag your "it" .... lmao
Scav
01-28-2020 01:06 PM
wrd0225
04-29-2010 10:19 PM
1984F250Man
01-26-2010 09:09 AM
mjohnston4314
06-29-2007 10:30 AM
whozat24450
03-26-2007 02:57 PM
Quick Reply: earlier diesel fuel tanks, 1984 to 1990
