2016, F250, 6.2, AT, Coolant Radiator Drain
What tool do you insert into the plastic tube to open the drain valve ?
Thanks. |
If there it is a 90 degree fitting , you might consider just carefully unscrewing the fitting.if it is threaded into the radiator tank.
