78 F350 camper special
Hello!
I'm new to this site and have a lot of questions about a project truck I just bought. I am a DIY'er so any and all information is deeply appreciated. However, I do know where the gas tank is :D With that being said, my first question is 'Where on the block can I find the engine size'?? |
Check the eighth digit of the vin, vehicle identification number, the letter or number there tells what engine is in the vehicle, unless it's been changed !
Post it here , we should be able to assist you. |
The eighth digit is the number 6. I don't know if the engine has been changed or not. Thank you
I see your reply , but cannot give you your answer until I get to the info this afternoon, unless someone else answers it sooner.
There were a few engines available that year. Is the engine in your project a six or eight cyl.
Of the 8's there were the 302, 351W, 351M. 400 and 460. Can't find anything with a 6 designation. Are you positive about that 6 being the eighth digit? Does it have a 2 barrel carb or a 4 barrel carb? Did you try the "Ford Vin number site" |
actually, the 4th character on the vin is the engine code; A-B are 6 cylinder, G is 302, H 351, M 390, S 400, J 460
hope this helps |
Thanks for clarifying that 80ford302. Could not find the correct info with the info I had.
it's no problem at all
Thanks Guys!! Big help...How do I know what kind of carb it has?
2 Attachment(s)
i believe the 2 barrel carbs are motorcraft 2150's or a carter, not sure but to tell if it's 2 or 4 barrel, 2 barrel on left, 4 barrel on right
| All times are GMT -5. The time now is 04:36 AM. |
