88 FI 460- no fuel pressure
running when parked last year
Installed new battery, cranks fresh fuel 1/4 in rear tank full in the front. Is there a fail switch / relay somewhere ? Thankshttps://cimg0.ibsrv.net/gimg/www.for...eba2fa4bc6.jpg |
Always check all the fuses first.
Also should be an inertia switch in the cab ,against the firewall over the trans tunnel. you can feel the depression to confirm the button is pushed all the way down. Sometimes it can get tripped if kicked hard enough. |
thank you for the info
was 36* here today, didn't get much done. going to check voltage at main pump, go from there |
