94 F350 Dually rear axel help please !! ??
We have a 1994 F350 dually.. And we are on vaction.. I noticed that we had a rear end problem when I was checking the rear tires... I saw that there were some broke rear axle bolts and that others were lose, all on one side.. Anyway to make a long story short, found used axel.. Need to know the bolt torgue for the rear axel bolts and the lug torgue for the rear wheels.. Please is there anybody that could help... Thanks so much in advance..
David |
RE: 94 F350 Dually rear axel help please !! ??
the wheels should be torqued to 140 ft lbs. as for the axel bolts i just zip them up with the gun at work
Thanks for the info on the lug nuts... But I still have a problem.. This is the second time this has happend.. I'm 600 miles form home at a truck stop and people that I've talked to say that I need to know the axel bolt torgue also... I would love to make it home with out any other problems.. I know you said you just zip them up with a gun but is there anyway you could at least give me a estamation on the foot pounds that you use... Thanks agien .. Any help would be great..
David |
