96 7.3L exhaust leak
Recently purchased a 1996 f250 with 135K miles on it. The exhaust has a leak on the driver side up pipe at the manifold connection. Do you have to pull the turbo to change the donut gasket? It is a Garrett turbo. In short, is there a quick easy fix for this? I'm already in the middle of replacing the down pipe from the turbo to a 3" 2 piece Diamond Eye outlet. I really don't want to have to pull the turbo!
you don't have too .. if you remove the turbo then you have to worrie aboutn lining up the y pipe and that is a pain
