96 e250-4.9 l
Old 02-28-2018, 11:06 PM
Crosleyjon's Avatar
Default 96 e250-4.9 l
I could sure use some help - My 96 E250 suddenly was hard to start-I changed the plugs ( Autolite ) new plug wires - Distributor cap/rotor-new ignition coil.
It now starts fine- however-now when driving at highway speeds-if you slow down-back off the pedal to near idle-it stumbles slightly-if you continue not to accelerate-it starts missing...The miss is slight-but if you continue to back off on the engine speed--it will eventually shoot a PO300 code.
The Van has 70,000 miles,I would appreciate any suggestion.I also looked everywhere for a vacuum leak - but no success locating.
Thanks
Last edited by Crosleyjon; 02-28-2018 at 11:10 PM. Reason: Did not mention Automatic Trans
Old 03-01-2018, 03:01 AM
From my experiences, I had less problems with Motorcraft plugs in Fords.
Had to learn the hard way, a lot of aftermarket stuff out there is cheaper, but the quality just is not there and some were defective right out of the box. The code could involve any of the parts you replaced. Random misfires can have many causes and somewhere along the line complete info is not getting to the PCM. It could be from a loss of crank signal at times to lean misfire .The 4.9 was pretty reliable. What other engine maintenance has been done, like fuel filter ,air filter etc.? EGR systems can also get into the pix.
Old 08-13-2018, 08:10 AM
Crosleyjon's Avatar
Default Fuel lines
My 96 E250 -4.9" needs fuel lines-which are not available-obsolete-no after market--are there any options ?
Old 08-14-2018, 02:45 AM
Which lines?
Old 08-14-2018, 06:30 AM
Crosleyjon's Avatar
The supply and return fuel lines from the fuel filter to the engine.
Old 08-15-2018, 03:40 AM
You might try ,Vintage Parts Inc
Beaver Dam, Wisc.
Old 08-15-2018, 07:48 AM
Crosleyjon's Avatar
Thanks for the help=as always
Old 08-15-2018, 07:49 AM
Crosleyjon's Avatar
Thank you !!!
wyteblazed
04-07-2014 11:28 AM
Jimmy22
08-09-2012 07:53 PM
coyote223
11-21-2007 05:44 PM
dmallard
07-24-2007 10:47 PM
Crash25744
12-14-2005 06:31 AM
Quick Reply: 96 e250-4.9 l
