AC compressor clutch & pulley replacment
Hi. I'm new here and need some help! I need to replace the clutch & pulley on my Ac compressor! Any body done this and are there any special tools required? Vehicle:2001 F-250 5.4L
Thanks for the help.Bob.
There should just be a few bolts holding it on. There are also shims to set/ adjust the clutch gap. You want to make sure that you have the correct gap or else it will either not engage, or it will stay engaged all the time. You will also have to drain and add both the refrigerant and oil if you remove the compressor. Good luck.
RacinNutt
Feb 18, 2011 01:32 AM
