Bad pcm?
Ok guys I have a 2000 f250 5.4 2v triton long story short I bought this truck thinking it would be a quick fix but I'm finding out otherwise using a snap on scanner the monitoring shows the pcm making the right bank run -25 and the left bank 20 I have replaced all plugs with motorcraft and gapped to .56 it has new COPS and I also pulled the injectors to check to see if they were stuck open they weren't I've fixed intake leaks and vacuum leaks I have 35 psi fuel pressure it has a new crank sensor and cam sensor I've cleaned the IAC and the throttle body and the MAF sensor the engine is literally running on 4 cylinders I can unplug the injectors on the right bank and perform a KOER test and it shows righ bank running rich I tested the O2 sensors and they were faulty but with new bosch sensors i have no change in result the only thing left is the knock sensor or the PCM I have no pending codes and the only memory codes were #4 cylinder misfire I need some help I'm a heavy equipment mechanic not auto lol
Please reread your post and correct accordingly. Once you check it you should find what I believe is an error. Thanks
(Post 98275)
(Post 98275)
What are the readings for the oxygen sensors?
If someone else worked on the vehicle earlier could they have switched the sensor plugs? A little more investigating as to just what the PCM is seeing/receiving may shed some light on just what is going on. Can you post some of the data? |
(Post 98279)
You might try creating a big vacuum leak and see if the sensors respond.
(Post 98284)
