blowing coolant
Old Sep 8, 2012 | 09:30 PM
RJ DAVENPORT's Avatar
Default blowing coolant
I have 04 f250 crew cab 6.0 is stock i did the power stroke soulotion yr and a half ago and remand tran has been fine no problems got a new t trailer about 6500 lbs now it wants to blow coolant out the degas bottle in the tow mod and when its not when i try to pull hard, anyone got any thing help pls txs
Old Oct 17, 2012 | 12:58 PM
Kik's Avatar
Kik
Ok not an expert but, I had a 94 F350 with 7.3L turbo. Kept blowing freeze plugs near the trans, had it fixed 2 times then one morning warming up in drive sitting idling all of the sudden the top blew off of the anti-freeze over flow. Wound up being blown head gaskets, compression was getting into coolant side and building pressure.
Old Oct 17, 2012 | 11:40 PM
Who installed the kit?
Was the reason for the kit prior HG failure? Heads were checked? Sounds like head gasket/s. With EGR deleted, any indication of coolant leaving the exhaust? Droplets on the lower bed, moist carbon at the pipe etc.
jeff308
May 25, 2010 05:29 PM
unrealmustang
Aug 3, 2006 01:27 AM
gripeit204lj
Apr 29, 2006 01:19 AM
hightonedsob
Jul 8, 2005 02:29 PM
josser
Jun 21, 2005 07:28 PM
