Brake light problem HELP!!!!!!!!
I have a 2003 f250 that the brake lights wont turn on when the peddle is pressed. I 've checked the fuses, bulbs, and the switch at the pedal. I need this truck to tow a trailer tommorow. Any help is greatly appreciated.
Applied brake lamp power out of brake postion switch/sensorto the high mount lamp is a direct circuit 'before' the MF.. The reason for the question.. Power out to the rear tailights is through the multifunction switch..
