crank sensor wire routing 2009 f250 5.4
Just purchased used truck. Looks like they had to lift the engine to replace AC compressor or possibly engine mounts. The crank sensor wire routing was pinched underneath the AC compressor, so Im trying to figure out exactly where the routing is supposed to go. Right now its connected with a plastic push in from the top front edge of the right side valve cover, then from there I need help. From that point the wire loom has two more plastic male type connectors, one has a round clip with it.
Question is , can anyone with a 2009 f250 5.4 gas attach some pics of the factory wire routing from the valve cover, around the pulley tensioner, and a couple more all the way to the ac compressor and sensor connection? Any help is appreciated. Tx |
