Crankcase and HPOP Reservoir
I recently asked a question about an oil additive advertised to help clean up the spool valves and reduce sticking fo the valves.
I asked if the additive goes in the HPOP reservoir or the crankcase. Answer was "The Stiction Eliminator is added to the crankcase. The crankcase oil circulates through HPOP reservoir also." I thought the crankcase and the HPOP were separate. Which is correct? Thank you. Eric |
HPOP oil is fed from the primary pump in the lower end..
