Driveshaft problem
Old Sep 24, 2007 | 03:29 PM
strokin04's Avatar
Default Driveshaft problem
i havea 03 f-250 , 8" suspension lift 38x12.50 tires.I dropped the drive shaft yesterday for the second time. nothing is stripped out thatI can see it just slips offin thefrontyou have to take whatever the f*ck its called that the ds hooks to off and pound it back on then reinstall andit's good to go.
Question 1: wouldmy suspension lift have an impact on the angle of the ds therefore creating this pain in the *** problem?
Question 2: whats an easy solution to fix this[/align]
Old Sep 24, 2007 | 03:38 PM
david paul's Avatar
Default RE: Driveshaft problem
u will probably have to go to a drive line shop and have driveshaft lengthened since u have put a lift kit in
Old Sep 24, 2007 | 03:41 PM
strokin04's Avatar
alright thanks
Old Sep 25, 2007 | 07:07 AM
Use Common Sense's Avatar
With the lift, you not only have to worry about the length of the drive shaft, but you also need to check your pinion angle and make adjustments there also.
Old Oct 2, 2007 | 10:52 AM
plowin@8800's Avatar
I'd agree- before you take it to the driveshaft shop, check the pinion angle relative to the driveshaft, if the angel difference is too great, you'll wear out the u-joints VERY quickly. Repositioning the drive axle to get an appropriate angle isn't very hard with all of the lift kits and accessories out these days. JMHO
pal0869
Apr 25, 2009 02:04 PM
krafty
Apr 5, 2009 08:06 PM
rdoble
Jan 5, 2009 05:20 AM
Mirage
Oct 19, 2008 10:29 AM
NYRAM
May 5, 2008 07:49 AM
