engine oil leak
I have a 2001 f250 with a 5.4 gas.I have an oil leak at the top of the engine at the rear of the motor. It appears to be a hose, and I am having troubles finding the leak.It is a pressure hose. When I run the engine it sprays, and worried it will catch on fire. Does any one have any experience?
thank you |
maybe the pressure hose on the power steering pump has a hole ! i had that happen before, the pressure hose cracked at the crimp on the power steering hose and sprayed fluid all over the place ! is it motor oil and not power steering fluid ?
