phatf-250 |
11-22-2013 06:27 PM |
f-250 ghost issue?!?!?!?!!
O.K. guys........I have an 04 f-250 5.4 sd....30,000 miles. About a month ago, I noticed a "stumble" or slight "bucking" while going 55 or so. then, coming to a stop, it will idle super low. But not every time! I have dropped tank,cleaned tank and blew out lines......replaced burnt out exhaust manifold.....replaced plugs coils and intake manifold.........replaced maf sensor......replaced idle air controller......problem is still there. I have hooked up, and watched while driving, fuel pressure tester....fine. I have done a smoke tst, and used propane, and carb cleaner to find any vacuum leaks.....I had two people hook up their code readers(nice, 10,000$+ machines) and can get all kinds of info, but the fact remains, both banks are throwing lean codes. Would camshaft pos. sensor do this, or how about throttle pos. sensor? All logical options have been explored. I do have an issue with my hub lockout on driver's side, but would this create a vaccum leak, if it is bad? I know they use vacuum to engage and disengage, but not sure if that is the issue. it likes to try to pop into 4x4 while driving, like it is full of rust, and does'nt really disengage completely. I'm so lost with this issue!:confused:
