F-250 super duty
I just purchased a 2006 250 super duty diesel crew cap I was wondering could any body tell what is the biggest size tire I can put on stock rim with stock height also I have a superchip power programmer for sale for a 2001 f150 4.6
RE: F-250 super duty
What rim size?
17" i believe 7' wide
S/B a 17X7.5...
A 285/70/17 (33") will fit with no problems.. Anything bigger like a 315 would most likely rub.. The 265's are a 31.5-32 I believe depending on brands.. If you don't go to big there isn't any need to recalibrate for tire 'oversize' (gem module) as smaller dimensional differences are calculated for... |
Ok thank you will look for some pro comps 285/75
I don't know of any brand that makes a 285/"75"/17.. "YET" ..Could be wrong though :)
The 285/70/17 is a clean fit in that MY.. If you do go alot wider on rims, or much taller tires, you may have to do a slight lift, like 2" or leveling blocks for fit.. These trucks sit nose down in the front and would have to be leveled to go to a 9"wide rim or greater to avoid rubbing up front.. Running 'tall' sidewall tires also compromises the side wall for sway/stabilty as well.. |
that was a typo 75 I use to have 265/75 on my 150 how hard is it to do a 2" levelin kit would look it with pro comp 285/70
