-   Ford F-250 & Ford F-350 (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/)
-   -   F350 stops running (https://www.fordforum.com/forum/ford-f-250-ford-f-350-15/f350-stops-running-24762/)
Freedomdriver Jul 10, 2011 05:40 PM
F350 stops running
http://odessafiredepartment.org/uplo...49/1559262.jpg
Hello people! I have a big problem right now. went from germany to Paris with a school class but I can't drive back, where I live. The problem is, the bus(f350;1991; similar to the one at the picture) only drives for about half an hour, than it turns off and I can't drive on, as the motor doesn't start again. Already changed water pump/coolant pump. The warning lights near the steering wheel say temperature is alright (about 90 degrees celsius), but when I open up the cooling system and look for coolant liquid, it is simmering/bubbling. I dont know what to do. Thinking about it could be something with the thermostat. Maybe someone of u really knows the problem and may help solve it.
with best regards and thanks for ur help!
Freedomdriver
Gary2Wheels Jul 12, 2011 08:46 PM
the problem you describe seems to fit the recall for the distributor ignition module.Some 1991 5.8 motors were found to stall unexpectedly as they warmed up,so there was a NHTSA recall requiring dealers to fix the problem...the distributor usually has to come out,and it's tight quarters work.
Freedomdriver Jul 13, 2011 05:25 AM
hey Gary, thanks for ur reply! you are sure it may not be something with the head gasket as well? (perhaps it is, I dont know).
Dont understand everything you wrote about NHTSA, so I have to ask.
"there was a NHTSA recall requiring dealers to fix the problem...the distributor usually has to come out,and it's tight quarters work. "
This is their homepage, right?: Home | National Highway Traffic Safety Administration (NHTSA)
Does the distributor send someone who repairs the ignition module, when I call NHTSA?
How much will it cost or is it a case of warranty?
"it's tight quarters work" - sry, what does that mean - is it complycated or does it take much time to repair?
thank you!
