Fuel pump no power & cant locate fuel pump relay 94 f250
I have a 94 F250 that just died when I hit a small speed bump. I found the inertia switch & its not poped so I check if I had any power to the inertia switch with light,, No power !! So I figure the relay is bad . I was told its in the Fuse box on left side of compart under hood . I change them all & still no power. Ive been told the relay is next to the master cylinder on the fire wall .. I cant seem to locate it . But if all the relays do work & still no power to inertia switch what could it be?? Please help :) It has the 4.9l 6 cyl Thank you all for your help
Originally Posted by jozepy24
(Post 52680)
| All times are GMT -5. The time now is 11:46 PM. |
