1995 ford f350
Old 02-13-2009, 05:44 AM
skikatana's Avatar
Cool 1995 ford f350
how do you adjust the automatic shifter. It reads almost on the Neutral on the dash but is really in 2nd gear.
Old 02-18-2009, 11:55 AM
If the selector is sloppy or hard to select the specific ranges, look under the column about half way down at the base of the 'main' column.. You'll see where the trans shift cable and selector lever attach to the shift tube.. There a 2 torx screws there that come loose and back out.. Make sure their tight.. If the shift selector feels tight without any excessive play, there's a 'thumb wheel' on the small white range indicator cable just below and behind the lower column dress cover.. Rotate the thumb wheel to correct the indication error..
Old 02-25-2009, 11:19 AM
carmania11's Avatar
I cannot understand it. Can someone make it in detail.
cbutkaiv
07-26-2015 04:18 PM
jogare
05-18-2012 07:52 AM
HorchataKing
03-09-2009 02:00 PM
Lariat 07
09-08-2008 01:40 PM
skikatana
06-29-2008 07:40 PM
Quick Reply: 1995 ford f350
