| Ford Fanatic |
Nov 11, 2012 12:06 PM |
High Idle on a 5.8L Windsor
I got a 1997 F-250 with a 5.8L . Did a quick EEC-IV test and it came up with tp sensor was bad. Motor ran in the fault safe position, shifted erratic at high RPMs. While replacing it, the gasket between the plennum and the throttle body had been sucked in. So I replaced both the gasket and the tp sensor, along with the air idle valve. started it up, no service engine soon lite, idled at 750. drive it 10 miles the idle is stuck at 1500 rpm. Rescanned it, it came up with code 111, system ok! Is it possible that it could have sucked in the new gasket? Sprayed W-D around the gasket and didn't hear any difference. There is no way to manually adjust the idle so theres nothing that out of whack. The throttle cable are fine, even removed them to insure that the idle wasn't effected by them. Any ideas before? I'm sure that this isn't a first, any help would be appreciated.
