horn wont stop blowing
2006 f 250 6.0 diesel crewcab. Drove about 100 miles left truck idoling for 10 minutes went in store and the hor bleww till i disconnected the battery and removed the security fuse.horn went off.now im driving again and the horn blew i hit the horn and it stopped.this morning I put the fuse in and alls good,whats going on
horn won,t stop blowing
there,s a short someplace, maybe under the steering wheel ! if there,s a wire touching metal it will blow the fuse again ! or it could be the horn relay !
horn
fuse wasnt blown
There have been times when the pressure pad on the steering wheel for the horn will make contact when it gets hot and expands. If you do have a security system you may need to check that more closely.
