Need help routing brake lines on 94 F350
Old 11-18-2010, 01:56 PM
John D in CT's Avatar
Default Need help routing brake lines on 94 F350
Hi all - I'm replacing the brake lines from the master cylinder to the front part of the frame and I can't remember how they were routed. I started on this project quite a while ago and then had to drop it. I thought I'd be able to remember how they went, but no such luck. In particular, there's a junction block with 3 ports (1 is not used) that bolts to the frame, and I just can't figure out where it's supposed to mount, and how the lines run from it to one other junction block.
What I really need are some pictures, which I obviously should have taken many of prior to disassembly. If anyone out there can help me with pictures I'd be very, very grateful.
Thanks, John D.
whateversclever
02-06-2011 12:36 PM
bobbybird11
06-10-2010 06:53 PM
jgbn444
08-27-2009 08:00 AM
muskrat
10-13-2008 07:20 PM
FordF450
07-26-2007 11:49 AM
Quick Reply: Need help routing brake lines on 94 F350
