Interior Light and Cargo light randomly comes on
2006 F350 interior and cargo light randomly turns on when truck is off. Ford mechanic said it was the security module which I replaced but it is still occurring. After engine is shut off about 15/30 minutes lights turn on for a few minutes and then shuts off and repeats until I unhook battery. When this happens there is a clicking under dash where wire harness (I believe from door) is connected (white block). Any help on the cause.
Originally Posted by Ladyet
(Post 127373)
Imagine my surprise when I disconnected the module, everything started working normally. I put the old module back in, and everything worked as it should. Suggestion: Identify and disconnect modules until the issue goes away - you may get suggestions of where to start by using ForSCAN or the Ford diagnostic software. Like my issue, the module might seem unrelated to the issue that you are having. |
